GTi clutch change
mike22861
GTi clutch change
Well todays the day to do the clutch I'm sure I saw an excellent article on here with a step by step guide but I cant find it, does anyone know where it is or have a link to it?
1992 BX 4x4 Gti aircon Silver
some other newer Nissans
mike22861
The clutch is seriously buggered its had some extreme mistreatment in its past It shouldn't be needing replacement at 56000 miles.Not by me my I add
mike22861
mike22861
Yes it is correctly adjusted and nice light action it just has no grip I suspect its down to the rivets if any driven plate at all. Its not a hard job it's just nice to follow instructions from someone who has done it make sure you don't miss a pipe to move or a bolt or dismantle half the car when there there is no need
mike22861
it was originally owned by such a person but alas I have photos of it doing a track day with a much younger guy at the wheel I think that was the bit that killed it also warped the rocker cover by about 1/4" and blew an exhaust gasket must have given it some welly as they say. No respect some people
Ian_Fearn
Its here...
http://www.bxclub.co.uk/diy/tdclutch/
I changed the clutch on my TD 2 weeks ago for the 2nd time and have changed a few BX clutches. I class it as a 2 day job working a sensible number of hours (its a 'bit' easier on a GTi 8v than a TD or 16v)
Are you doing it on a 4x4?? If so, its a rather different job and worth doing some research before hand. I've only ever known it done on a 4x4 by removing the engine and gearbox plus transfer box complete.
Over and out from me
mike22861
yes its the 4x4 its same as the 8v gti once you remove the transfer box from the back
Did you sort the clutch in the end? It's been a long time since I did any work on a 4x4, but I think the crucial factor will be whether you can get the transfer box out with the engine in situ. If you can, it'll be as simple as a standard clutch change, if not it'll be engine and box out time. It would be interesting to hear whether the above method is practical?
djm666
BX 4X4 clutch replacement
on the 4x4it is just as easy i have found to pull the engine and gearbox and transfer box out and work on it on the floor with no bx round it.
i had to modify my engine crane to tilt the engine at a hell of an angle but i found it was a piece of piss this way.
then you can pull the cover off the back of the gearbox and check the splinesfrom gearbox to transfer box, which sometimes is the problem and not the clutch, especially if it has a hard life in the past.
also there is a special oil in the transfer box, i ordered 20litres of it from citroen, as you are ment to change it very regularly to maintain good transfer box health.
so the big question is how did you get on?
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
