For Repair/ Breaking: Paul's 1992 red 1.7td TXD !7 Day sale!
ruffgeezer
Post by ruffgeezer »
Ok well as you may know, Paul's bx was recovered in to our garage at the weekend with a burst hydraulic pipe, he has asked me to offer it here as a whole or for parts.
This is what she looks like in her current state:
Ok now for the 411 on what she actually needs, we've already covered the fact that it'll want a set of front to rear pipes replaced, and realistically those on the rear subframe want doing too.
When Paul first brought the car to us to have the fast idle module replaced we also noted the following on his paperwork:
  • RH outer CV boot split
    Both rear tyres worn to legal limit (they are both now past the limit)
    Slight play in both rear suspension arm bearings
    Corrosion to LH boot wall (this has since been fibre-glassed from the inside, pictured below)
    Corrosion to RH + LH front wheelarches/inner wings (I have pictured this, but I haven't poked it, it wouldn't take much to go through.)
In addition to this, I have taken pictures of some of the above, as well as the other iffy patches, you chaps can make up your own minds I'm sure as to if you want to attempt a save or if you want parts.
Paul has given me a target figure for recouping money for the car, and I've started a list of parts that are viable, they are as follows:
Rear lights
Wing mirrors
Headlamp protectors
LH headlamp
LHF indicator
Set of locks + 1 key
Chrome grille
SMR Bx Gti wheels 5.5" wide 2 tyres are knackered (I have had an offer on these)
Interior
Tailgate with spoiler
Much else would affect the value of the car as scrap (I have had it "valued") so we would need to take that into account when prices are discussed.
Please pm me with offers for parts, or any requests (I do not do "stairway to heaven ;) )
Edited to add: I can only hold the car for another 7 days, then it will be going to the scrap mentalists I'm afraid.
If by some chance nobody mentions the headlight protectors I'd advise taking 'em off anyway and putting them on eBay - they seem to go for silly money! Can't see why myself, but each to their own...
May be interested in the chrome grille?
. . . headlight protectors . . . on eBay . . . go for silly money!
Yer not wrong Harry! Infact, if you are an owner of a pair of that much sought after accessory, it might make economic sense to buy an extra pair of headlights to protect the protectors! (it would just look a bit daft?) :D
(Hope it works out for Paul and he manages to recoup some of his losses - seems like a nice chap.)
Well done Tim for doing this!
Paul get off your arse and sort this out, it's your problem not Tim's????
ruffgeezer
I am happy to help, Paul is a nice chap so it is really no bother to sort this out for him.
jacksun1987
Post by jacksun1987 »
Thanks tim
im sure if we make a bit of mony we can split it or somthing.
Mind you i have spent near 1000 pound at bullwinkles
PAUL JACKSON
cosa 1.2 brezze 150 k had
jacksun1987
Looking at them photos theres a big differnce between somone like me jo public. And a trained eye i didnt evern know all of that was there. The only ones i knew was the holes at the back.
PAUL JACKSON
Is the nsf wing damaged at all? the one on my TZD is the same colour but badly scratched, but straight and rust free
Also I will be passing bullwinkles on Tuesday morning at about 11am ish, and the down to london on the Sunday if that helps anyone with parts?
ruffgeezer
The wing has been resprayed at some point so sadly the top is a different colour to the side.
The car is due to go by the back end of next week so get your offers in chaps!
Hi, i'm interested in the rubber pipe that goes from the lhm tank to the hydraulic pump please, only if its in good order, the one on my tzd split at the pump end so couldn't be re-used :x And how much please?
ruffgeezer
Right today the following went:
Headlamp protectors, pressure regulator & acc. sphere, dousier valve, callipers, RHR door and the chrome grille.
Also sold are the wheels.
I'll check the pipe on monday Mulley.
Wooscary
Post by Wooscary »
If parts are available I'd be interested in the cold start advance mech that sits just under the fuel filter, and the fuel primer bulb. And a rear hub bearing cover. If at all possible
Would postage be possible on these as they are quite small? And what payment options are available?
Martin
ruffgeezer
Martin: Pm'd
Mike E (uk)
Post by Mike E (uk) »
I am interested in the front height corrector and connecting pipes (if in good condition)
Thanks,
Mike
