Hydraulic return pipe
Preacher
Post by Preacher »
Wondering if somebody could advise as to possible sources for the return pipe on the lhm reservoir that has the 3 pipes next to each other coming off it. If I've understood the parts list from on here right I think the part number is 96 119 048.
I think its the ends of these that connect onto the metal pipes ontop of the front cross member, that are the source of my persistant mot failures. :?:
1992 BX16 TXS - NOW back on the road
rabbercelt
Post by rabbercelt »
hi,I,ve just gone through the searching for the part you describe.Your part number is correct.Autoworld Chesterfield advised me it was available within 2 working days at a cost of £57.15 +VAT.I guess you could try them or another main dealer that might be closer.
Good Luck
Graeme
Preacher
Post by Preacher »
Thanks Graham, will check for availability closer to home. Getting a drnkers reputation for lhm otherwise.
