Fast tick time (was Changing hydraulic pump)
Changed the accumulator sphere at Mat's last night, but general consensus is that the pump is knackered. I'm getting the STOP light on at tickover sometimes, and the pump is running near continuously.
Happily, we were heading to a BX parts place, so I got a replacement pump for a tenner. Question is, what is the trick to replacing it without getting LHM everywhere? Does the system need de-pressurising for this?
I have to admit, I don't know how you would tell the difference, and I was the one who suggested the pump might be at fault. Apparently the steering doesn't feel notchy, and the assistance is always present. If it is the pump, then take care with the main LHM feed from the tank, as the pipe may be a little weak after all this time (although perhaps better to find any likely failure points now rather than on a journey?) It may be better to remove the belt and high pressure outlet pipes first (6.35mm seal needed), remove the pump and lift it higher than the LHM tank before removing the feed pipe, to minimise spillage of fluid.
i would think if the steering is good/ok it is not the pump at fault,
if the pump was slow/lazy the steering would suffer,
it might be easier to remove the bleed valve from the regulator with tray under to catch the ball bearing,
then i understad people (as i have not tried this as yet )place the bearing back in the regulator and give it a sharp blow useing a copper drift and hammer,
then re/fit the bleed valve bolt,
a sharp tap with a small hammer, not a big whack with a sledge hammer is all it needs. Do make sure the punch you use is brass or copper though (or any soft metal) since you really don't want to put a flat spot on the bearing..
Just as an aside, have you checked the lhm? It might be one of the issues that is causing the higher than normal clicking sound if its really old as the viscocity disappears with age, so it'll be much thinner & therefore the pump has to work harder to ensure the pressures are what they are supposed to be.
It probably is what has already been suggested, but i'd always do a proper lhm change for hydraflush, has been known to cure groany struts, tired steering & make the brakes razor sharp again & give the suspension a smoother ride as it cleans out all the crap in the system thats been clogging up the important bits.
I haven't changed the fluid yet. The existing fluid is nicely bright green, but then I've probably put at least 2 litres of fresh fluid in it since I got it.
The exact symptoms are quick tick rate (constant on tickover) and slow to rise unless revs are raised. I do wonder if the tickover is a bit low. Hasn't got a rev counter but it feels a touch low.
Matthew is hydraflush really this magic? Could many of the improvements be down to lack of leaked gas in the system?MULLEY wrote: It probably is what has already been suggested, but i'd always do a proper lhm change for hydraflush, has been known to cure groany struts, tired steering & make the brakes razor sharp again & give the suspension a smoother ride as it cleans out all the crap in the system thats been clogging up the important bits.
