The part number on the box is ok, but is this the correct rear cylinder for a saloon
Mike P
P*I*K in a top hat comes to mindMULLEY wrote:If the piston is a different size between the estate & hatch, as long as the cylinder dimensions are the same, just swap over the pistons etc... into the new housing
