Parts clear out.
Aerodynamica
Parts clear out.
Post by Aerodynamica »
I am clearing some parts. Mostly I have a stock of CX bitz but there are a number of BX items.
The clearout zone:
I'm hanging on to the CX bits but I think the BX bits are wasted here so they're up for grabs.
I have one or two good parts and some less interesting bits for the BX but before actually going through the lot to verify what I have, from general glancing I have the following available:
Series 2 BX NSR door card and handle in a black/red upholstery - think it's the TXD trim.
one door lock barrel but no key - is this of use to anyone?
2x door locking mechanisms - central locking I think but need to check - both LH side doors.
1x hydraulic pump
1x PAS pinion valve (NOS)
pretty boring so far I know, these items will have to hit the tip if no one wants them! I think the pinion valve and HP pump will be spared that fate though.. but what about the juicy pair of BX front struts I have!?! complete with regassed 400cc, 1,9 damper spheres. Anyone need these? not going to be expensive.
PM me if any items are sought, think they'll end up on ebay in the next few weeks otherwise :|
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
PM sent
anaconda
Post by anaconda »
Hi PM sent....creaking struts!
1991 BX TGD Saloon
1990 VW T25 Camper. Currently on sabbatical
Aerodynamica
Hi amigos, wow those who PMd certainly pounced!
Sorry Defender 110, I didn't see a PM from you. Anyway, all parts are now spoken for but there's one or two new items found, I added them to the end of this post.
For the benefit of those inquiring via PMs, here are photos of the parts taken today:
firstly, the Pinion valve:
Can anyone confirm visually that this IS a BX pinion valve? and not a ZX as could be a possibility..
Next, the Struts:
HP pump:
Note that this is the earlier style green-coloured and metal-encased BX pump. It came out of my old BX Mk1. It is in good order and was only removed as I managed to source a reduced-price brand new pump for that car (later, black, plastic-cased type)
Other parts found today!!
Semi NOS distributor with manufacturing fault.
Bit of a story to this dizzy. I bought a new, reconditioned dizzy for the Mk1 BX16 (that's the model it's for btw) only to find that the drive dog on it had been fitted 180deg the wrong way! I couldn't remove its roll pin to refit it the right way despite being assured it would come out with a drift, as I had limited tools. Anyway, I decided to make a hybrid new part out of the new one and the car's existing one (it's in a thread on here somewhere) so the car was finally fitted with a distributor with the 'new' upper half including cap, rotor, upper body with magnetic pick ups and the connecting wire. It worked a treat but left this lesser distributor with a used cap, rotor, and magnetic device but with a brand new lower body including shaft, advance capsule, and seals. Just that the drive dog is on the wrong way round.... anyway, it's yours for a fiver plus postage. Just PM for more info if needed, mind it's for a BX16 carburetor, manual.
Headlight:
It's used, in OK condition and resealed glass. But I used black sealant not white as it's Tiger sealant which is very good. Say £3 plus post? Comes with bulbs too. It's a near side headlight.
Door card from a TXD ( think)
There's also a door lock barrel but no key. It's about as much use as a freezer in the desert... free to anyone who wants it.
There's a second BX HP pump too but it's not in as good condition as the pulley is a bit out of true. I was thinking of making a 'CitroJim' style Sphere tester out of it' but if someone wants it £3 plus post as I have a spare CX series 1 pump to use for that.
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
Doh! nothing in my sent box either, I must have done my usual trick and forgot to put something in the subject box so it didn't send :(
certainly looks like a BX pinion, it has the different sized ports whereas a ZX has the more usual setup
anaconda
Post by anaconda »
You see..gazumped by the evil Defender...such a bad mother... :D 8)
1991 BX TGD Saloon
anaconda wrote:You see..gazumped by the evil Defender...such a bad mother... :D 8)
Not by me brother, my PM never got sent?
