Haynes BOL is silent on the location of both the DimDip relay and resistor pack - does anybody know where they are located please?
A fusebox diagram with relays annotated would be a good idea - does one exist?
1993 1.9 TXD
I am trying to isolate the problem outlined
http://www.bxclub.co.uk/forum/viewtopic ... highlight=
Relay Locations
The relay for dim dip operation is next to the rear washer bottle, under a black plastic cover. The wire colours may help you identify which one it is. The resistor is located on the front crossmember behind the bumper and is accessible by removing the radiator grille. It's a silver cannister with a connector on one end.
pmh
