I have recently purchased the silver 19RD on the forum, which didn't look too bad to start with, but is now making me pretty concerned that it's on the edge of being a scrapper... but hopefully I can bring her back, as she drives lovely (apart from the clutch...)
I was hoping I could get some pointers from those more knowledgeable on BX's so I can try and find the best (and cheapest) way to keep her going.
I needed a cheap car to tide me through after redundancy last year, but it seems that maybe the amount of repairs needed to this one now I have been able to dig in deeper, may cost more than I can afford, but I hope with advice I can keep her going.
I have maintained and restored H vans, 2CV's and my 67 DS, but never had a BX before.
1. The offside front strut gaitor (dust cover) has split, I guess the strut has to be removed to replace this, but is there a source for the gaitor/dust cover alone?
2. My 2nd biggest worry is that while doing a temp repair on my leaking centre exhaust pipe until I can get a new one, I saw that the hydraulic pipes passing the O/S rear sub frame front mounting point are all badly rusted. Can anyone advise the easiest way to repair these, does the entire set of pipes need changing front to rear, or can the damaged parts be replaced with jointed in sections, as the pipes are fine either side of the sub frame mount and where could I find a replacement set of pipes?
3. My biggest worry is rust.... The closing panel at the base of the c pillar on the door shut on both sides has had a major amount of filler in it. One sill has a patch part way along the rear door opening, the B pillar bases have had a little bit of filler in and both end of both sills seem to have been filled a lot and are now revealing a lot of rust. Finally both inner front wings have had a fair bit of filler in it seems..... I do have access to a fairly reasonably priced welding guy, but I am wondering how easily repairable the sills are using just patches, or if really whole new sills are needed and if available?
4. Both my electric front windows are very slow/stiff, is this just a case of cleaning and lubricating the runners, or something more required?
5. A friend of mine who has had a BX before thought that the spheres were a little tired. I don't think they are bad, but wondered if there is somewhere near Bedfordshire that could check the pressure? The front ones have a yellow sleeve on the top with a threaded section under the tube; does this mean they can be re-pressurised?
Any/all advice really welcomed, as I really want to make this into a usable car that has a second life, but sadly she has just been used for many years as a work horse, with only basic care. I will be making a post in the wanted section soon for some of the bits I need to try and keep her going, as the MOT is coming up soon...
Many thanks, Simon
