My Cars: 1999 Xsara LX 2.0HDI (90) Hatch - Fern 2002 C5 2.0 HDI (110) Estate - Jasmine - SORN 2011 Mini Cooper D Clubman - SOLD 2016 Mercedes A180D Sport - Auto refinement 1992 TZD Turbo - Bluebell - SORN 1992 TZD Turbo Estate - SORN 1991 Gti 16V - Blaze - crash damaged, will get repaired - SORN 1990 Gti 8Valve SOLD - looks like it's been scrapped 2002 Mini Cooper S - SOLD - i miss this car 1992 TXD - Scrapped in March 2014 1988 CX 25 GTI Turbo2 - SORN 1996 - AX Memphis 1.5D - Dream - SORN
Alfaman kindly spotted that my brake lights didn't appear to be working, apparently they flickered on & went straight off.
I've checked them & noticed that if i press the brake pedal gently, nothing happens, only when i press it harder do they come on.
I'd be grateful if anyone could let me know what might be the problem? Just what you need when driving in the dark I'll be using my foglights manually just incase they aren't working.
My Cars: Land Rover Discovery Series 1 200tdi 3 door Land Rover Discovery Series 2 Facelift TD5 2020 Fiat Panda cross 4x4 twin air.
Postby Defender110 »
brake light switch just wants adjustung.It's a micro switch that screws in or out to adjust the sitch on point.
Postby MULLEY »
What does it look like? Just want to make sure i only fiddle with the right bit
from memory it is screwed too far in if the lights are not coming on till the bottom of the pedal; You undoe the lock nut, take off the 2 wires, unscrew the switch a couple of turns and try the pedal (you will here the switch as it opens and closes) then when you get correct adjustment , nip the lock nut back up and reconnect the wires.
Just a thought, before you adjust the switch make sure the little plunger is releasing ok and not sticking. It should slide in and out easily with movement of the pedal.
Postby MULLEY »
Cheers for that tip, i'll squirt a bit of lubricant down it if its sticky.
