Mickys blogalog
Re: Mickys blogalog
You have my sympathy with the school parking. I live 15 yards from our primary school, when I go out I have to time it so that I can park within quarter of a mile of my house! The upside of that of course is that I do the school run by standing by the front window.
(now sadly gone)
(now sadly gone)
198x Citroen BX16 TRS auto
1991 Saab 900 16v convertible
2007 Lexus RX 400h SE - x 34
Re: Mickys blogalog
Hopefully that'll get the bastard then Mick! Nothing like camera evidence.
2006 Lexus RX 400h SE hybrid
Re: Mickys blogalog
no luck catching the guy that hit my car so far ,
the car has just passed the 115,000 mile mark and apart from a temporary leak from the bottom hose on Thursday is doing all it should when it should , still takes a lot of cranking when hot but have learnt to live with it and just wave at anybody who stares for too long ,
sorting out heater panel lights and the cable that has come unclipped then its onto the bodywork
Re: Mickys blogalog
Ah, the old hot starting a petrol BX routine. I used to find pressing the gas peddle down sometimes worked. When it didn't pumping the gas peddle sometimes worked -when that flooded the engine (which it usually did) getting out and screaming; 'you worthless piece of shit' didn't help either but I did feel better somehow. When you get really hacked of with the whole pathetic charade there's always . . .Mickey taker wrote: still takes a lot of cranking when hot but have learnt to live with it and just wave at anybody who stares for too long ,
Diesels
- x 17
Re: Mickys blogalog
IIRC the correct hot starting method from the owner's manual for carb equipped BXs is to hold the throttle pedal part way down when cranking.
- My Cars: LOTS!
- x 123
Re: Mickys blogalog
The sticker on the window of the 16TRS (the same mechanicals) states just that, weird that the GT has the same carb yet jumps into life first time when warm with no gas, yet the 16TRS wont unless I give it some "pedal".mat_fenwick wrote:IIRC the correct hot starting method from the owner's manual for carb equipped BXs is to hold the throttle pedal part way down when cranking.
Re: Mickys blogalog
sticker in TGS says foot to the floor for hot starting , it works ( eventually )
- My Cars: LOTS!
- x 123
Re: Mickys blogalog
Mickey taker wrote:sticker in TGS says foot to the floor for hot starting , it works ( eventually )
Same one then, think the carb needs setting up? TRS was abismal to start when I got it, changed the carb for a rebuilt one off a scrapper and its much better.
Re: Mickys blogalog
it actually says
WARNING- HOT START-START WITH ACCELERATOR
FULLY DEPRESSED-DO NOT PUMP-
maybe I should make it very sad and not fart
Re: Mickys blogalog
yay , my special mate Nigel came over with his thin fingers and had a rummage down below,
the hot /cold knob now works as it should
where I had been trying to get full range from hot to cold the cable at the heater tap end had snagged which is what caused the clip to pop off at the knob end !!!
Re: Mickys blogalog
did an oil change today in less time than it took Andy Murray to win the first set.
Would have cleaned the lhm filter to if I could of found the guide in the tech section doh !!!
Re: Mickys blogalog
I did mine the other day too, sadly my genius idea of trying to drain the old oil directly into an old petrol can didn't work very well, splashy splash.
RE hot starting I just start cranking and slowly depress the loud pedal down until it catches, seems to work fine and avoids an epic VROOM of just planting it
Re: Mickys blogalog
well I think the BX has caught on that the trajet is going soon due to its replacement arriving tomorrow.
The battery light has stayed off all day
and I have fitted my illuminated window switches as well ( very subtle )
tinkered with the mixture on the carb and have got the tickover much smoother.
mind you I did think of selling the BX to buy a 68 Humber sceptre ( free tax dont you know ) but someone beat me to it
Re: Mickys blogalog
new people carrier collected today from Blackburn, a couple of teething problems that the garage sorted out immediately and being as I had seen less highly specked models for £2,000 more down my way it was well worth the drive. going to be strange driving a diseasel again after all this time but hey ho
- x 17
Re: Mickys blogalog
So what have you got to replace the Tragic?
Glad you like the switches!
