couple of bits wanted please
do's anyone have a couple of mudflap clips to spare,I have two missing also do's anyone have a passenger side front seatbelt socket(bolts to seat) they could sell me as mine is broken and finally if someone has a front splitter with fixings for sale, I would be interested. Thank you
x 26
Mick; I can send you the seat belt bit and I think I may have some mud flap clamps, I'll check when I get home tonight.
Thanks Kevan, you are becoming my personal saviour , dont spose you have a working heater tap with all the cable's do you ?
bit hopeful ? , I thought so too :lol:
Jayboy
Post by Jayboy »
Don't forgot not all seatbelts are the same so one belt might not necessarily be received by a clip from another BX. Been caught out like that before. Check the belt clips in before going to the hassle of fitting the replacement clip to the seat!
CCC BX Columnist
'89 16v P1
'93 ZX Volcane TD 3 Door
'98 Xantia Activa P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
thanks for that I will check before fitting
so its just the front splitter now then :lol:
x 70
With your seatbelt, mine chewed 3 in a year, so in the end I prised it apart, cleaned it all up, greased it all up and it's worked fine for 2 years now.
mine works but the casing is damaged
