BX Front Struts
BX Front Struts
As these are nigh on impossible to buy these day's, whilst i was looking on e-bay, i came across some C5 Front struts as per below:
http://www.ebay.co.uk/itm/2001-CITROEN- ... 3cbedc43b8
Visually they look similarish in size? Has anyone ever had a look at these to see what dimensional differences there are & whether they could be adapted for the BX to run on LHM (C5's are LDS aren't they?), this is obviously a bit of a long shot but was wondering as these type are readily available & are cheap.
KevR
Post by KevR »
Sounds like a job for Riku!
Post by ken newbold »
As far as I know, C5s don't run on the green stuff, they use something different.
KevR wrote:Sounds like a job for Riku!
Nah, surely he'd make a whole new strut from some old scaffold tubing found lying around? :lol:
ken newbold wrote:As far as I know, C5s don't run on the green stuff, they use something different.
LDS, i mentioned that in my original post :D
rmattila
Post by rmattila »
Having no idea, I would guess that the C5 suspension needs a bit more force, while the system pressure is more or less the same => the piston diameter might be a bit higher.
I've occasionally wondered if it would be possible to grow back a corroded front strut piston by some clever electrolytic method and then somehow machine it to accurate dimensions, but since I already have more than 10 overhauled struts waiting for an eventual need, this has not been a very high priority issue. !!!---)))
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
It's OK, I can't read, I only look at the pictures :oops:
:lol: :lol: No worries.
