O/S drive shaft intermediate Bearing wanted
hvanman
Hi, the intermediate bearing on the drive shaft is very noisy on my 17TZD Turbo estate, so I think I have to bite the bullet and fix it.
I have looked up a few threads, but not been able to find the part number yet, but I see that at one time GSF did the entire shaft for not an unreasonable amount, although I suspect it will have gone up now if still available.
Before I start shopping around I thought I would ask here in case anyone has a spare bearing, or even a good, complete O/S drive shaft I could purchase?
Cheers, Simon
Cheers, Simon
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
1992 BX 17 TZD Turbo
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
here is price, part No. and dimentions from service citroen for diesel fuel except ABS the bearing is the same for ABS cars as well,
0000324703 BEARING 20.60 GBP 24.72 GBP 24.72 GBP
this bearing is not easy to remove as it is quite a way down the shaft
sdelasal
hvanman
Many thanks Malcolm, if nothing else comes along I will have to go down the route of changing the bearing on my current shaft.
The symptoms I have is a rough bearing/grumbling sound from near the pedal assembly area, that tends to increase with speed and seems worse when taking a left hand bend. It is easy to ignore, but once your ear has tuned in to it, you realise that it is not a noise that should be present....
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
Brian
Hi Simon,
I very much doubt it would be the drive shaft inter bearing.
As the rumble changes when turning left, more likely to be a wheel bearing.
They are quite difficult to detect which side is causing the problem, as wheel bearing noise does travel over the car.
Even when jacked up, disk pads released, and the wheel is turned,
because the load is on the non worn part of the bearing.
But worth a try, you may be able to detect.
Good luck
Good luck
hvanman
hvanman
OK, thanks Matt, I was hoping for a bargain... £27 new on eBay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... TQ:GB:1123
Still, it may be a wheel bearing anyway and not the intermediate one anway!
Simon
Simon
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
kk-kolonel
Can 8V or 16V driveshafts be temporarily used in place of the turbo diesel ones?mat_fenwick wrote:No, they are different unfortunately. 4 different types for the BE gearbox cars - turbo diesels and the 16v had a larger diameter driveshaft to cope with the torque, the rest are identical apart from ABS and non ABS versions.
I have a severe noise in mine and want to replace it or repair it - I bought a pair of non ABS joints as I had been told they were the same.
On stripping it last night, it appears that it is a silly one piece combo with the outer joint non removable from the driveshaft.
I assume the 8V is the traditional type of driveshaft with a splined removable joint.
Would 1.9 petrol 8V shafts and joints fit my BE gearbox and hubs while I send my diesel ones off for rebuilding? (not factoring in the 8V driveshaft strength as they will only be temporary)
Cheers for any help.
'91 BX TGD - sold then brought back and found to be in a very rough condition - has gone to the great chevron in the sky but had to be done to keep my other 2 on the road
'91 BX TZD - daily driver
'93 BX TZD - recent purchase making into a very tidy example
16v and turbo diesel ones are the same. You can use a shaft from an 8v model as a temporary solution (and probably permanently if you're prepared for the slight extra risk of failure) as the hub and gearbox splines are the same.
Strange what you have found with the one piece shaft - would suggest that this is a non standard pattern part.
kk-kolonel
Cheers heaps for that..
Will swap over and chuck up some pics to show - looks very factory - but who knows with cheap chinese remade parts....
Cheers again. (apolgies for thread hi-jack)
Gibbo2286
If you have the bearing off read the numbers on the rim and ask any bearing specialist to match it.
My local guy did so and charged me a tenner for the bearing which he already had in stock.
http://www.rwbearings.co.uk/
Oilyspanner
Oilyspanner
