I remember someone on here saying they could make these up.
Please would they contact me as I would like a few as I can't find those I need on sale.
thanks,
Mike
BX Hydraulic pipes
Mike E (uk)
BX Hydraulic pipes
themildbunch
There was an eBay seller offering a custom pipe making service - just found this ebay ad not sure if it's the same seller though - probably easier and cheaper than buying your own flaring kit and bits but he only does 3.5mm not the other ones...
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Mike E (uk)
Nat
what do you need, I have a load of piping left over from doing half of my car and a tool.
If its just a few smaller lengths I can cut them to lenth, put the ends on and then you just have to bend them to fit (very easy by hand)
got both 4.5mm and 3.5mm pipe too
away for the next week though so wouldn't be till a week sat that I could do any
1991 BX 4X4 GTI back on the road
Mike E (uk)
Thanks Nat,
The pipes I need are those that connect to the front height corrector.
I want to service it off the car, then refit it, and I doubt I can remove it without cutting the old pipes.
Will try to get under the car in the next couple of weeks, when I have cleared the remains of a Peugeot 406 from half of the garage.
There's a drink in it for you.
cheers,
Mike
cheers,
Mike
Stinkwheel
Hiya all,
just saw this thread. I can do the 3.5mm have pipe and ends here.
If thats any use, drop me a pm with the lengths you need.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
