BX parts for sale - UPDATED new parts added Friday 8th April
davidb
Post by davidb »
First of all a little introduction.....
As you can see I am a recent member but I am also a retired Citroen dealer of 30 years based in South Cumbria. I retired 8 years ago and when we closed the garage I ended up with a lot of older Citroen stock which has been stored at my home and cellar ever since. I am now sorting and selling off these parts with the help of my son (the computer stuff!). I have quite a lot of BX parts and all my original microfiche and machine so I can look up part info as required. Below is a list of the initial set of parts I am looking to sell and hopefully can be of use to some BX enthusiasts. Please note that unless stated otherwise these are NOS (new old stock) Citroen parts.
Please bear with me as I get used to selling parts using the forum and send me an email or pm if you have any questions or if interested and I will work out postage for you.
David.
Updated with new parts Sunday 8th April:
Early BX rear bumper grey £40 SOLD
BX Front left full door all models £70
BX RH front wing (some surface rust) £25
BX saloon LH rear wing £40
BX RH front door glass clear (see photo) £15
BX RH rear door glass clear £15
BX LH rear door glass bronze tint £20
BX saloon rear quarter light upper plastic panels LH & RH £5 each SOLD
These fit above the smoked perspex panels and are unpainted plastic.
BX brake pipe doser valve to safety valve (96093542) x2
BX brake pipe front left hand caliper to union (95596539) x1
BX suspension pipe - front suspension cylinder Rh to union (95600541) x1
BX brake pipe LH rear from caliper to union x1
£10 for the lot SOLD
Still available.............
BX Automatic kick down cable (BVA) (2444 79) 1986 > £12 SOLD
BX air intake hose (91510821) BX Petrol 1580cc carb £4 SOLD
BX radio cover for black interior 16v etc. (95635020FXX) £15
BX wiring harness front to rear lights (95635338) £15
BX diesel large thermostat 1986> (93501145) £5
BX suspension pipe union (5447189) x 2 - £2 each SOLD
BX cut out switch (168095) 17,19 & turbo Bosch £20
BX Control lever (95624967) for wing mirrors x 2 £3 each
Knob for wing mirror control lever (95633648) x 2 - 50p each
Temperature sensor switch BX 1.4 cast iron (133772) - £3
BX reverse switch 16v diesel & turbo (225741) - £4 SOLD
Retaining clip rear susp cyl (95563033) 50p
Resistor for cooling fan (95576443) - £10
3.5mm pipe seals (96085785) x 18 - 25p each SOLD
6.5mm pipe seals x 4 (96085783) - 50p each
BX front wheel bearing circlip (334535) x 5 - £1 each
BX front crankshaft oil seal (51472) x 1 £3 each SOLD
BX 1.9 diesel front camshaft seal (23614) x 2 - £2 each SOLD
BX 16 front crankshaft seal (32622) £3
Sump washer small x 23 - 20p each SOLD
Sump washer large -6 - 30p each
Apec rear caliper kit (springs, clips and covers) £4 SOLD
BX air intake grill (95573724) Petrol 1580 injection & 1905 > RP4923 x 1 £4 each
BX diesel front air intake panel (95595 734) - £20
BX Water intake unit - engine rear (1336G4) BX19RD > RP3795 £4 SOLD
Various badges
Only badge left = 19TRS
BX Rear water tank hose 22-25mm (1307W4) RP5714 onwards x1 £2 each
Various rubber trim pieces:
BX LH rear door trim (95612071YB) £4
BX RH rear door trim (95612072YB) x2 £4 each
BX front LH door trim (95612064YB) £4
BX LH rear wing trim (95612064YB) x3 £3 each
BX RH rear wing trim (95612065YB) x3 £3 each
BX RH front wing trim (95612059XX) x2 £1.50
BX 14 TU engine rocker cover gasket £2.50
BX diesel thermostat housing to cylinder head gasket (pack of 5) x4 £2 each
BX 14TU exhaust to manifold gasket x2 £1 each
BX 1360cc clutch cable RP4193 onwards (96081711) £15
BX 1360cc clutch cable > RP4192 (9561702) £15
BX 1.9D & TD water outlet housing RP3796 > RP5637 (1336.47) £30
BX CV boot clips 4 per bag x1 (7903083156) £2
BX diesel front height corrector linkage (95573984) £25
BX front headrest grey check (quadri jersey) > RP3767 x2 (95618813FTS) £15 the pair
Plenty to come as I sort through boxes.
If you have any specifics parts you are looking for drop me an email and I will have a look through what I have.
Thanks for looking.
Retired Citroen dealer.........with a shed full of parts.......and the cellar........
x 150
Hello David
Welcome to the club, I am sure you will be a popular man, LOVE those pattered front headrests, not sure what they fit mind you! I fancy buying them just because.
I will bet those black headrests wil be gone by the end of today! 8) :lol:
x 19
Could I claim the return pipe from tank to power steering distributor (95603421), caliper repair kits and strut return pipes please?
Depending on where you are in South Cumbria, I may be able to collect on the weekend of the 18th Feb.
davidb
Post by davidb »
Mat_Fenwick
Sadly we are at a wedding that weekend. Let me get a price to post for you, don't think there is much weight in any of that. Will mark those items for you and will PM you the cost.
Thanks,
octopus return pipe please
strutt return pipe please x 2
BX front calliper brake (with abs) flexi pipes x2
wiper arm please
PM sent
EDIT: Sorry Matt didn't mean to step on your toes, I hadn't seen your request whilst I was typing.
If you come across a heater tap could I be first in the queue please
Post by RxBX »
mat_fenwick wrote:Could I claim the return pipe from tank to power steering distributor (95603421), calliper repair kits and strut return pipes please?
Defender110 wrote:octopus return pipe please
wiper arm please
PM sent
Kevan, I reckon Mat has put a reservation on the strut return pipes :wink:
Hi, Dave (And welcome) I hope you don't mind, as I put the picture/image link in correctly so as to display (Below) the photo of your Front (ABS type) brake calliper flexi pipes !
BX front calliper brake (with abs) flexi pipes x2 > RP3886 (95632790) £10 each
I sure you will be very popular with you BX sales, I hope you do well !
:D
LH front indicator unit please! :D
PM me the total, when you're ready; no immediate rush.
Phil
themildbunch
Contact:
Post by themildbunch »
Hi.. just emailed about the estate lenses and the remaining return multiply thing!
You don't have a TD bottom hose by any chance?
Thanks..
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
x 150
Can you put me down for the other wiper arm please! Paypal ok?
bx petrol auto saloon
BX parts for sale
Dear David
If the door mirror is for a mk 2 David, could you kindly put my
name to it please.
Many Thanks
Vince.
47,594 Miles from new.
Owned for 3 years sorned.
69,000 Miles from new.
Owned for 15 years T & T.
davidb
Post by davidb »
Vince
Will put your name against the mirror. Will check tomorrow if mirror is suitable.
Many thanks David, if you come across any more caliper seal kits or P/S return octopus I'll take them as well.
Mat, thanks for sharing the strutt return pipes bud.
Hi David. Could you put me down for the black gti rear headrests and the 16 valve clutch cable. I'm in Lancaster so can collect in person. Also if anyone else wants to me to collect parts for them I'm more than willing to help. Regards Mark. ps if you come across any more 16 valve specific parts I'll take those as well. Desperate for some front mud flaps as mine are pretty shot.
BX PARTS FOR SALE
Dear David.
many thanks for putting the door mirror to one side for me David.
Could you pease put me down for the both height corrector springs too aswell.
I am need of another door mirror for the other side too.
I am in need of both handbrake cables too if you have any David.
I too need a heater tap aswell, but Susan is more desperate than
I, so a used one may help me out a bit.
I also after 2 or 3 air filter housing spring clips, good used ones
may be fine too David
I am after too a good used pair, or new ones, of 2" x 1" rubber
buffers that sit ontop of the front wing edges, to dampen the bonnet
as it is closes. I am also looking for new w/trims or very very good used 14".
and a new or very very good sunroof delector, I have a new that is
cracked, so I have a new seal and the fitting kit already, also a new set
of black steel wheels too, and a new front wiper arm if you happen to
stumble across another one David would be magic :wink: and also
some new mk 2 headlamp protector too
Could you very kindly let me the price total including packing and
poastage too David. PM me if you want to confirm anything David.
I am in Kent TN10 4AB I am at home all day everyday so feel free
to ask any questions and once again David thanks a million :D
All The Best and enjoy the wedding next wekend, I hope it is in
Barbados or somewhere else warm :wink:
Again David many, many thanks indeed.
Vince.
