EARLY TZD TURBO
EARLY TZD TURBO
http://www.ebay.co.uk/itm/1991-CITROEN- ... 4ab3cf89be
Low miles, P1 16v alloys, and no reserve?
Could be a good buy for someone, doubtful it will have ABS at that age too?
Needs a bit of a fettle, but looks good - nice low mileage for a diesel as well.
(note to self; Paul, don't even THINK about it!) :shock:
Reluctant BXpert
Post by Caffiend »
I'm tempted if it can be got for the right price and I can find someone to trailer it - straight to where it'll need to be repaired :lol:
Not far from me either.
Certainly worth a punt. 350 - 450 might be about right in it's current condition? Probably a few bob to get it sorted but a low miles, up together TZD (with alloys) is definitely worth thinking about (but not by me obviously! :D )
''needs a new radiator'' ? is that because it is leaking or because the engine is over heating.
Caffiend wrote:I'm tempted if it can be got for the right price and I can find someone to trailer it - straight to where it'll need to be repaired :lol:
You can drive a car to the MOT station/place of repair as long as its booked in, and its insured and its going straight there only.
Can't remember seeing a TZD Turbo in that colour for ages, its the exact same shade as my old Gti.
Reluctant BXpert
Post by Caffiend »
Yeah, I'm happy to spend a few hundred quid if I can get it for around the 400-very-ish mark. I wondered about the radiator as well, I'm not sure I'm up for a third head gasket in my life of car ownership :shock:
Not sure if it's driveable with rad leaking though Tim? - unclear from ad, should contact 'em and ask.
IF it's just a leak, then so long as the coolant level remains OK then it should be safe - you can (temporarily) run without the expansion bottle cap to minimise pressure. But do all the usual HG checks (oil/water mixing, make sure no bubbles or build up of pressure after a cold start).
Also bear in mind no temperature gauge, and new radiators aren't cheap - I've seen them for around £150 but don't know if that's good, bad or average.
Hurricane
Post by Hurricane »
Upto £225 with 5 days left, this could get tasty.
K BX 19 TXD
J BX TZD Turbo Hurricane
J BX TZD Turbo
have emailed seller re rad Problem, might buy it for the alloys and then sell it on for £100 less with steelies on it. should make it back from Chesham to MK ok if not a neighbour has a car trailer he might lend me:lol: unless someone wants to buy it with me ( I chip in a ton,you get the car , I get the alloys )
this is the reply I got
they used to run hotter at speed , but could sit in a summers day traffic jam for hours and never overheat, but that's an airflow issue built in by design !!
but on ebay he has put
Rad defo shot , it has corroded at the bottom of the core, the vehicle was stopped and towed home before any damage was knowingly done, all 5 spheres were replaced before the rad went , the car had £400 spent on it on the spheres and other bits and pieces, if my dad had the money to put a new radiator in if and not been given a seat Toledo for nothing ,it wouldn't be for sale as he'd still be enjoying driving it , he hates the Toledo with a passion !!!
Oilyspanner
Post by Oilyspanner »
Just in from doing the head gasket for a bloke who thought it was okay to drive a vehicle with a leaky radiator, thing is he bought a new rad three weeks later anyway, it cost £66 delivered, and took an hour to fit, the head gasket job is probably going to come to about £300 by the time its done, trailer it if you win it or take a rad with you when you collect, my TZD had two seized cooling fans , must have been like that for years, I have a TZD radiator in the garage that is crusty but probably usable as a temporary measure.
Date of Liability 01 02 2013
Date of First Registration 30 04 1991
Year of Manufacture 1991
Cylinder Capacity (cc) 1769cc
CO2 Emissions Not Available
Fuel Type HEAVY OIL
Export Marker N
Vehicle Status SORN Not Due
Vehicle Colour GREY
Vehicle Type Approval Not Available
anyone on here thinking of bidding on this as I don't want to get in a bidding war over it if I can get a trailer
