Door Pins
- Tim Leech
- x 141
No rush Ian, I will be fitting the newly painted doors soonish, but they wil be just the shells etc for a bit so I can get everything checked and cleaned before I refit them.Dollywobbler wrote:I haven't forgotten the door check straps you still need back either. Just haven't had chance to investigate yet.
Re: Door Pins
Hi Tim,Roverman wrote:As per advert, need a couple for the DTR, as they broke when I persuaded them out of there resting place.
Prefer postage!
Cheers.
I'm sure I'll have a few in my bits and bobs box, yours for free if I find a couple, give me a call tomorrow !
or:Vanny wrote:there a pretty standard size, so you might be able to get them from a decent iron mongers or possibly a ships chandler (assuming either still exist!)
My local family run motor factors stock them so yours may too
- themildbunch
otherwise called roll pins - I bought a few in the exact BX size for some crazily small cost at my local fastener suppliers.
I think the Citroen cost is £7 each or something...
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Tim, I'm still awaiting for you to respond !RxBX wrote:Hi Tim,Roverman wrote:As per advert, need a couple for the DTR, as they broke when I persuaded them out of there resting place.
Prefer postage!
Cheers.
Then you'll find outRoverman wrote:Cheers chaps, Richard if you do come across some that would be great.
I must come and pick up the other bits from you sometime.
here is all families these pins fit from service citroen
Information about the search
Number of documents found by vehicle family:
2 document(s) found for BX
6 document(s) found for AX
1 document(s) found for C15
and here is price and part No.
00006999CJ HINGE SHAFT 1.68 GBP 2.02 GBP 2.02 GBP
- Tim Leech
- x 141
Many Thanks Malcolmcitronut wrote:here is all families these pins fit from service Citroën
Im due to pick up some door panel clips from my local stealer so will run it past them.
Or as at least 3 people have tried to tell you above;
a tupence apeny roll pin from any local motor factors or engineeing supplies.
- Tim Leech
- x 141
Depends on how good your factors are thoug Kevan, mine are if you give them a part number, otherwise I draw a blank. Will give it a whirl though.Defender110 wrote:Or as at least 3 people have tried to tell you above;
