Frozen diesel
KevR
Frozen diesel
Post by KevR »
Not in the car, in the forecourt pump! Coming back from UK the other night, landed in Dieppe at 4am with a couple of hundred miles to do and went to fill up. It took several minutes to dribble the first couple of litres into the tank, then it filled as normal. Can only assume the fuel had almost frozen in the lines and pump above ground.
Radio told us shortly afterwards it was -14°C thereabouts that night so that might have something to do with it!
