Steelies AND/OR Trims WANTED
- x 27
Hi there,
If anyone local to me - or is going to the X Rally has a set of 4 'holed' 5.5" (as per GTi) steels they'd like to sell/offload, let me know. Tyres not important but if they did have decent rubber on them, then I'd still be interested.
Last edited by Philip Chidlow on Fri Feb 17, 2012 6:16 pm, edited 1 time in total.
- x 27
Alloys: been there, done that lol!
Now, I am also after a set of TZD/GTi trims - or Meteor trims for the TGD's 'solid' steels; I don't like the original (valave-cover-less) originals. I have a set of 'universal' trims but they don't fit the rim (don't 'click' in).
Does anyone want to sell me a nice set?
- x 27
Nat
- x 27
Aren't those 5.5 stellies ultra rare Phil? I doubt anyone has got any, unless they are fitted to an 8 valve Gti & there aren't many of those knocking about with steelies fitted these days.
- x 27
Any reason why you wanted to fit the larger steelies? It would be easier just to get the alloy's tbh if you wanted to fit wider tyres than the standard 5j sized steelies.
- x 94
- x 27
I wanted to fit 185 profile tyres. And my experience of alloys recently has been they're hard to get properly balanced, as well as being a few quid more than steels.MULLEY wrote:Any reason why you wanted to fit the larger steelies? It would be easier just to get the alloy's tbh if you wanted to fit wider tyres than the standard 5j sized steelies.
I have 175 profile winter/all-weather tyres on the standard rims at the moment, so I was thinking I'd keep them on there and fit 'new' (part worn) summer Michelins on the wider rims.
But I suppose I do have a set of decent 165 profile tyres here, so there's no real need to get the wider steelies - except they will have better ventilation,
There's no rush, but I would ideally like it sorted in April... and given the amount of mountain driving on the Challenge, good grip and good brake ventilation are something to consider.
- BXpat
- x 94
Except the trims on that Saxo aren't the same as the trims on that BXFrTed wrote:Naaah.Kitch wrote: Except I'm pretty sure they're not Saxo trims![]()
I'm thinking Berlingo Multispace myself.
Saxo. I should know.![]()
http://upload.wikimedia.org/wikipedia/c ... 071002.jpg
Though I will admit the rims are Xantia.
Trims on BX:
Paxo plastic:
- x 94
Kevan, I think what Phil meant that his current 5" wide rims are of the Solid type, as opposed to the 5 1/2" ones With Holes which was what he was after, hence better ventilation of the brakes (provided you've not got the solid 'Z' trims fitted of course)Defender110 wrote:Why does a wider steel give better brake ventilation?
