suspension
SILVER SLIPPER 11
suspension
Post by SILVER SLIPPER 11 »
bx diesel suspension will not raise , is it the the pump ,no leaks anywhere ,no clicking sound ,,,any idea,s cheers mark
sdelasal
Post by sdelasal »
Two things then ...first start at the pump - is it rotating? Second, is there enough lhm fluid - check that fluid reservoir level okay and there are no oil slicks under the car?
SILVER SLIPPER 11
sdelasal thanks levels are ok pump turning from the belt on the engine no leaks cheers mark
Gibbo2286
Post by Gibbo2286 »
Some micky taking neighbour undone the bleed screw? :D
Gibbo2286 wrote:Some micky taking neighbour undone the bleed screw? :D
Oi ' Ive never even been to Nuneaton
has the hight lever been droped to its lowest setting :roll: :shock: :wink:
is the STOP light going out if not there might be a split in the suction pick up hose at the tank,
Pressure relief valve bearing stuck.
Kitch wrote:Pressure relief valve bearing stuck.
/\ yes , undue your bleed screw nearly all the way and it will probably free itself, a tap with a hammer may help if needed.
:? Is this the same car you dangled for free and then retracted on a previous wind-up then proceeded to slag various forum members off? :shock:
http://www.bxclub.co.uk/forum/viewtopic ... sc&start=0
Isnt this the chap that sold James that shitbox of a TXD Turbo a few years back that he ended up scrappping? :?
Post by ken newbold »
Self and same. :evil:
SILVER SLIPPER 11
citronut Kitch Defender110,, thanks for reply had a look can,t see any thing wrong ,is it rare for the pump to stop working cheers Mark
