Nice Looking TZD
Nice Looking TZD
http://www.ebay.co.uk/itm/CITROEN-BX-17 ... 4cfe96f8a5
Heres a good example of why you should always get your cambelt changed regularly!
Camshaft will be in bits & the cam bearing caps will either be damaged or snapped as well. Might be lucky & thats all that needs replacing, or would the valves be bent as well?
JayW
- x 13
BX Meteor
[quote="BX Meteor"] Mick, London isn't too far from MK, buy it for the splitter, nice set of wheel trims too !!
out pedanticing the pedant
umm, not that I'm looking but, funny how its got an electric mirror switch but manualy adjustable mirrors !!
looks like it may have some sort of alarm fitted as well ,(sensor just above the steering wheel )
sell on the interior £50.00
body panels £30.00 each
splitter priceless
still have the trailer problem to sort out ,
splitter priceless
Mick !Susan Donym wrote: out pedanticing the pedant![]()
splitter priceless![]()
Standard UK spec. TZD's normally have a passenger side electric mirror and a manually operated drivers side, hence the switch
Also those fog lamps look in good nick, there worth a bob or two (if they are) ?
BX Meteor
no that's obsessing on detail in picturesSusan Donym wrote:out pedanticing the pedant![]()
don't get a trailer, get a low loader £95 for 250 miles
yeah, I thought they were original BX covers/trims, but I just looked closely and they're not, however he says "5 Good Tyres"Roverman wrote:They look like wheetrims to me!
Whatever anyone does with it, it could be good value to buy with £95 to collect if you live within 100 miles of London.
Oscar
You could always stick the engine from the ZX in this car and have one of the few 1.9TD's and yours would probably be unique in that it would be the only one that does 30odd to the gallon.
sorry
Incidentally you don't need to look too close at the wheels to see that they are cheap nasty wheel trims on this, all BX's I've ever come across only have 4 wheel studs.
