In an uncharacteristic moment of clarity I've decided because replacement GTi/TZD hatch-style 'dishy' trims have not been forthcoming, I am minded to refurbish the 'orrid (but correct) TGD trims I have here. They have lost much of their paint but aren't too bashed about. No valve covers of course, but that doesn't bother me too much.
So, does anyone have any tips as to how best go about this?
They are flexible to a degree, so unless I get the prep, priming and finish right I fear they'll go all flakey in no time.
What silver paint should I use? I don't want them too brash, and the original silver looks quite 'flat'/grey.
Wheel trim refurbishment
- x 25
bx petrol auto saloon
Wheel trim refurbishment.
Dear Phil.
When I was a full-time car valetter Phil, If on your last coat of silver
spray, before it dries, I used spray a coat of clear laquer on whilst the
last coat was still wet. and this dulls down the very bright really silvery
paint, and also gives you a surface that you can clean and polish, as
opposed to one that requires washing al the time Phil.
Hope this helps Phil.
Take Care.
Vince.
PS Don,t forget to use panel de-greaser to clean the wheeltrims before
you paint them to avoid pickling.
Take Care.
Vince.
47,594 Miles from new.
Owned for 3 years sorned.
69,000 Miles from new.
Owned for 15 years T & T.
- x 25
Dear Phil.
That,s a pleasure Phil, no trouble at all, That one about the laquer,
goes back to when I used to be painting lots and lots of Rostyle wheels,
by hand. and without masking them off either. I used to be really enjoy
doing the wheels and the trims, I got to be pretty good at it
All The Best Phil.
Vince.
All The Best Phil.
Vince.
All I'd add to the above is it might last a little longer if you use plastic primer
Jayboy
Excellent i'll try and remember this, thanks Jayboy, most silvers are too silver for trims.Jayboy wrote: Ford Moonstone Silver was a perfect match on the AX, and TG trims were the same shiny silver colour back in the day.
