Auxiliary fuel tank
axbx
Auxiliary fuel tank
Post by axbx »
Any ideas on where to put it in a bx break? And is this hard to mount onto the already existing system? How does one switch between the two?
Thanks
:idea:
messerschmitt owner
Post by messerschmitt owner »
where the spare wheel sits and move the spare wheel inside?
Won't do much for rear end crash safety though
Citroen XM 2.1TD SX hatchback
Citroen XM 2.1TD VSX estate
Smart Roadster
Fiat Punto Cabriolet
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
BX-less at the moment!
If it's "just in case", isn't a jerry can in the boot easier, safer and will allow the BX to return more mpg? :wink:
axbx
Post by axbx »
No its not for when running out of fuel, its to be able to run on two kinds of fuel, and switch between them when suitable ;)
