Alternator issues
ritmo
Alternator issues
Post by ritmo »
Hello everyone. A little advise needed.
Dodgy alternator in Betty, my back in '93 TZD. The one in there is a rather flimsy looking lucas example. I think 70A output.
I bought a brand new second hand Valeo alternator out of a 93 ZX with a the 1.9TD engine. So I thought it would fit, it being pretty much the same engine. However, the mount is totally different and it doesn't fit.
A. Does anyone know if I can get a mount that will fit in my engine bay for the valeo alt?
B. Does anyone have a descent alternator I could buy off them?
C. Any other suggestions? I have my engine bay in pieces at the mo, with the radiator out, I need to sort something quickly!
Thanks for any help, very much appreciated!
Jake
If you go to a metal shop & take both alternators, i'm sure a mounting plate could be made up so that the wrong alternator can be made to fit. Aside from that you'll have to get a correct one :cry: All the best in getting it sorted.
ritmo
Post by ritmo »
Does anyone have any opinions as to whether this one will fit?
http://www.ebay.co.uk/itm/280839749877? ... 1423.l2649
The mounting brackets looks very similar to the original one.
Thanks
JayW
x 13
Post by JayW »
Looks right from where i'm sitting (on the sofa) :wink:
Although i'd suspect the terminals *may* be different.
ritmo
Post by ritmo »
Thanks,
Looks right to me, knowing my luck the PCD will be 10mm out or something.
Vince Pepper
My Cars: 1989 PH2 16v. White
Seat Leon FR. Whiter
Post by Vince Pepper »
I got mine from GSF, cost £54 exchange, bite the bullet and get the right one, less aggro in the long run.
ritmo
Post by ritmo »
I should, but it's :shock: £273 -£120 exchange for this type. I think the TZD has a higher powered alt.
Vince Pepper
Point taken, that's very expensive
CGATCX25GTITURBO
Post by CGATCX25GTITURBO »
could try repairing it, if it a swap out regulator / brush box... it's simple to do :)
missing my 1992 BX19TGD
1987 BX19 GTI 8)
19TD temp 2 Xantia estate :)
600 Bandit 97 :)
ZX12R 00 :evil:
