Hi all. I need to adjust the belt on my tzd hp pump. Could somebody tell me what size spanners I need please?
Thanks
Mike
TZD hp pump adjustment
mikesg
- Good Old boy
ritmo
Not sure of the spanner sizes, seem to remember it being a 12 or 14, but just a quick pointer. When I did mine a while back I was told to put the belt on really tight, so I did. However, it lasted about 3 miles. Don't do it up too tight! I think you should be able to twist the belt to 90°, that's worked for me for the past couple of years anyway.
an 11mm spanner for the slider nut and 14mm for the pivot bolt,
they do need to be very tight or the belt will slip,
mikesg
- Good Old boy
Thanks for your input gents
Mike.
Mike.
