Something strange has happened twice now to the 17 TZD that maybe someone has some idea's on??
On approaching a junction and down changing, while the clutch has been down, all the lights come up on the dash and the engine stops.
Letting the clutch up to jump start it, or stopping and using the key results in the engine starting straight away. (this happens while maybe still 10m from coming to a full halt)
It has only done it a couple of times in several thousand miles, but is a bit worrying in case it happens at a time when acceleration is then quickly needed....
Any suggestions gratefully received.
Thanks, Simon
Cutting Out Mystery
hvanman
Cutting Out Mystery
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
1992 BX 17 TZD Turbo
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
Oilyspanner
I once had a Lotus Europa that stalled every time you pressed the clutch, that turned out to be worn crankshaft thrust washers that allowed the crankshaft to be pushed forawrd each time you pressed the clutch.
hvanman
bill o
hvanman
The tickover speed seems fine. It does sometimes "hunt" a bit before settling to a smooth tickover.
I have not come across an anti-stall device before (always petrol before), I have the Hayes B.O.L so will see what it says, although any extra advice would be welcome.
Thanks.
Thanks.
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
KevR
+1 for that - on the roto diesel pumps there are two actuator arms on one spindle on the belt end of the pump, and these should be able to move independently. If they stick, for whatever reason (rust, dirt etc), the anti-stall device doesn't work, so if the revs drop very suddenly, the motor stops. I think Haynes covers adjusting it reasonably wll, but first check that the arms are free to move otherwise adjusting won't do much!bill o wrote:Ihave had this problem in the past,the anti stall device needed adjusting.
hvanman
hvanman
