Diesel pump swap....?
oilybox
Is swapping from Lucas CAV or Roto pump to Bosch type an easy job ? .... Just in case my Meteor doesn't have the Bosch pump.... As I intend to go the veg oil/diesel mix route eventually....or will it all need 'setting-up' again afterwards?
mechanically-minded, technically-gifted,....self-confessed fix-it yourself fan....
Re: Diesel pump swap....?
At the moment i wouldnt bother with using veggie oil as its the same price as diesel, a least it is around where i live and i havnt seen any offers in any of the supermarkets i go to. You will have to go to a lot of trouble which probably wont justify the expense and if you cock it up your Meteor wont run at all.oilybox wrote:Is swapping from Lucas CAV or Roto pump to Bosch type an easy job ? .... Just in case my Meteor doesn't have the Bosch pump.... As I intend to go the veg oil/diesel mix route eventually....or will it all need 'setting-up' again afterwards?
- x 25
Oilyspanner
As stated you will need pump, pipes and injectors, that said I put a lot of vegoil through a rotodiesel pumped BX with no problems, I have also swapped pumps over, there are two lots of holes in the alloy pump mounting plate, swap the studs into the other three holes and its away, I would get hold of all the bosch bits, put them in a box, and then run vegoil through the rotodiesel
c90cassette
bosch pump
hi is woth running bosch pump on veg oil except very cold weather!can stillbuy 20l for £20 from asian wholesale shop or costco,bye rob.
hi i am rob in liverpool 1989 bx 17 dtr turbo
mike st gilles
1 litre of Veg oil at the Pound shop is ......surprise, surprise.... yes 1 pound. I'll let you guess what it costs at the 99p store........I put that at a saving of around 49/48p a litre compared with derv. (excuse lack of pound sign....I'm using an american keyboard and it doesn't have the pound sign only the $ one)
Mike
Bit off topic here.mike st gilles wrote:I'm using an american keyboard and it doesn't have the pound sign only the $ one)
I use a kiwi keyboard made in Thailand
1990 BX19 TZS Auto 06/11/1989
