can you run engine with pressure relief screw undone ?
BX Meteor
Post by BX Meteor »
I've got a leak in the rear suspension above the rear exhaust box and I want to turn the car around to be able to work on the back more easily.
LHM pisses out even on low suspension, so can I undo the pressure relief screw and move it like that ??
If not then I'll have to take off the pump belt ffs.
Yes but LHM will p-ss out of the pressure relief valve then; So no! :?
BX Meteor
Post by BX Meteor »
/\ thanks, I thought so, I'll have to remove the belt then :x
I would have thought you will have difficulty moving it on low as the car is probably "grounded" on it's exhaust system.
Sounds like you have a fracture in a front to back HP line where the lines pass over the rear subframe. :(
My sympathies on tackling that. You need to hinge the subframe down to achieve access otherwise it is almost impossible to thread the new pipe through.
BX Meteor
Post by BX Meteor »
Yeah you're right, it was difficult to move but the exahust system was not grounded (I fitted it myself a year ago, which is why).
I'm going to reverse it onto ramps and remove the back exhaust box, it's only been on a year and the car has not done many miles so it should come off.
If the pipes are as difficult to do as you say, then I may not bother and sell parts on here and then scrap it.
Mick, you may get a "round thing" (or if you pay for low-loader hire you can have car complete).
EDIT: although, a few years back I did replace the rear brake supply pipe that runs from the front to the T-piece and the other suspension pipes run with it.
x 103
Way2go wrote:You need to hinge the subframe down to achieve access otherwise it is almost impossible to thread the new pipe through.
I did this a year years ago in the street in a half day, I didn't touch the subframe. I did however use kunifer piping (very flexible) rather than a new 'pre bent' pipe.
Actually, once the exhaust was off, i found it pretty straight forward to do. The hardest part was tracking down a pipe flaring tool.
BX Meteor
Post by BX Meteor »
/\ makes sense from what I remember of doing the rear brake pipe (the one to the 3-way T). When the exhuast was off it was easy to get to all the pipes. The four that run down the side (HC main supply, HC return to reservoir, HC return to brake cyclinder, brake cylinder pressure to rear T-piece) were easy to see and run fairly nicely round the rear sub frame to their respective places.
However, the nasty bit was getting the union undone, I managed to get the pipes going to the rear calipers off the T-piece and then cut the feed that was leaking and put the T-piece in a vice to remove the old union. If the union for the one that is now leaking will not come off in situ on the HC then that will be the mother of all nightmares.
owning a meteor is such fun isnt it Brian :cry:
BX Meteor
Post by BX Meteor »
:cry: :lol:
x 103
Erm, i failed on that, actually i need to do something with it.
Ultimately i put an in line union and joined old and new pipe at the splitter.
bx petrol auto saloon
Can you run engine with the pressure relief screw undone ?
Dear Mr Meteor.
I am so sorry to here this Brian :( can you get new unions from
Pleiades or Chevronics Brian :?:
Can you let me know what part/s you are worried about Brian :?:
I can see if I can help you " On-line " Brian :wink:
Hope this helps.
Vince.
47,594 Miles from new.
Owned for 3 years sorned.
69,000 Miles from new.
Owned for 15 years T & T.
My experience of front to rear pipes is that if one has gone, then the rest is probably not far behind. If you're planning to keep the car then it may be worth dropping the subframe and changing them all.
BX Meteor
Post by BX Meteor »
Then I might get it going long enough to drive it to Syd's :lol:
BX Meteor
Re: Can you run engine with the pressure relief screw undone
Post by BX Meteor »
bx petrol auto saloon wrote:Dear Mr Meteor.
Hope this helps.
Vince.
Hi Vince
Not to worry, there are places to get pipes made up
Alternatively I could do what Vanny says, get a flare tool and leave the remnant on the union
When I've got it up on ramps and removed the exhaust,
then when I can see more, I will make up my mind on its fate :cry:
thanks, Brian
BX Meteor
Post by BX Meteor »
This could indeed be a nightmare to fix
Steps taken so far:
1. remove alternator belt and slacken pump belt (easy)
2. turn car around (fraught, as no power steering and no brakes)
3. get car up enough for jacks (annoying, had to tighten pump belt and run engine just enough to lift car to get jacks into position both sides)
4. jack car up on both sides and put axle stands along both sides (easy)
5. remove both exhaust boxes (easy)
6. Unions on the HC look problematic. Leak may be main pressure feed into HC. I'll have to see which ones I can undo. Nightmare :cry:
See here for 15 second video (two short clips and two photos thrown together)
First part of video is with engine running (no exhaust boxes) with suspension set to low
