Cam belt change interval?
ben
'morning gents does anyone have a rough guide as to what mileage intevals cam belts should be replaced ?
This is on my n/a BX TXD .
I believe the recommended interval for this engine in a BX was 36,000 miles, although I'm happy to be corrected on this.
The interval for the same engine in the ZX was increased (I think) to around 60,000 miles, but this is close to the limit for these belts as I remember a rash of failures on cars that missed this change by a few thousand miles.
- Reluctant BXpert
citsncycles wrote:I believe the recommended interval for this engine in a BX was 36,000 miles, although I'm happy to be corrected on this.
Just to be really awkward, I thought it was on the service schedules at 48,000!Dollywobbler wrote:Gawd knows. On my Peugeot 306, it was 72,000 IIRC. I didn't leave it that long though. More applicable these days is a 5 year maximum. It isn't just mileage. 40,000 miles is probably sensible. I've a feeling that's what I had in mind with my last BX.
I wasn't going to say anything as not 100% certain, but I reckon 48k miles/X years is what I've read too. I do have an Citroen service book so can find out what the official line was in 1993, if I can remember. I'm certain the recommended intervals changed with time - certainly the oil change interval for the diesels was initially 5k miles but later extended to 6k as (presumably) the number of engine failures were sufficiently low.
It's an obvious incentive to push the recommended cambelt change interval past the mileage limit of the 'inclusive free servicing' packages that were becoming common at the time...
ben
Oilyspanner
JayW
- x 13
The best answer is: If you're asking or considering it, then just do it!
Service quoted mileages are based on very "standard" conditions generally set by lab testing but many things can affect your personal intervals.
Use, lack of use, cold short journeys, long motorway miles, good oil, poor oil, good maitenance, poor maintenance, quality of original belt, ambient temp between countries and a whole host of other factors.
Having a snapped belt last year on the TGD at 38k i'd say "frequently" or at least every 5 minutes
BX Meteor
While your changing it do the water pump as well. Saves on the labour costs at a later date as the pump is more likely to leak after being disturbed by the cambelt change.
btw, Harry Haynes says 36,000miles it is a matter of opinion though how often it should be done! After 36k your on borrowed time.
1990 BX19 TZS Auto 06/11/1989
I get the same problem with the GS - Haynes says to change it every 24,000miles, while the Autodata book I have says to simply readjust it every 12,000 miles and not change it! at 26k since the last change, and having to take the front of the car apart anyway to sort a leaky hydraulic pump, I'm doing them now, along with a couple of oil leaks
Later diesels are 48k or 5yrs whichever comes 1st. I've only ever heard of quinton hazel cambelts breaking sooner than 48k.
Discoil
Erm, well overdue regardless of mileage tbh, they degrade due to age, so not worth the risk imho.
