Belt keeps breaking. HELP!!
Chris Abbott
The belt from the HP Pump to the cam shaft pulley has broken 3 times in a hundred or so miles! What do i look for? Im not overtightening it, it doesnt slip, it just keeps fooking well breaking!!
Advice please
Advice please
JayW
- x 13
That IS very odd! Only 3 real possibilities:
Drag on the pump (pump knackered)
Overtightening (are you sure?)
Poor alignment (are the pump and pulley correctly aligned?)
It's also worth inspecting the broken belts to identify HOW they're breaking. Are they chaffing or being over-stressed?
Although what Jay posts are possibles, I would be surprised if that could cause breakage within such a short distance. Are these belts of the correct quality and have they been properly stored?
For example if they have been badly stored or are flood-damaged stock, then the reinforcing cords could be rotten?
Check the edges of the pulleys for signs of damage, as a belt pinched that way can go in a few hundred miles. Also check the pulleys are straight on the shafts - if one's out of true you may be lucky and it's the pulley not the shaft that's bent. I had a Lomax that shredded alternator belts in a few hundred miles which turned out to have a bent crank
Chris Abbott
Right........ The pulleys are in fine condition and line up. I,ve changed the pump with another one i have knocking about still the same, my mechanic pal reckons it could be the Flow diversion valve causing the problem? Any thoughts on that one? What i did forget to say in the 1st posting, the steering is a bit stiff at times, worse when turning right hand down.
JayW
- x 13
It's possible the filter in the FDV has become blocked and therefor not letting the LHM from the pump in. This would cause drag on the pump essentially making it go stiff (as i don't believe the pump itself has a PRV).
Cleaning out the FDV is relatively easy but it'll need to be off ther car.
thorter
Chris Abbott
Oilyspanner
have you studied the brocken belts if so did they snap, chaff through inside or on there outter surface,
maybe if the later there is something touching the belt,
or are you pinching the belt on fitting were it goes over the bottom of the pump pulley,
Chris Abbott
citroen7
as jay says this happenened to me on my estate that had been laid up prior to my purchase i got a spare fdv from the scrapyard (that shows how long ago that was!) and then bought a refurb kit fot the original unit ,it was full of black gunk and bits of rubber in the filtersJayW wrote:It's possible the filter in the FDV has become blocked and therefor not letting the LHM from the pump in. This would cause drag on the pump essentially making it go stiff (as i don't believe the pump itself has a PRV).
Oilyspanner
