Wanted Bumper Screws
As per advert the dome done shaped hex screws for on Mk 2 cars (not the posidrive mk1 types) also if you have plastic receptors that clip into the body too.
i belive this is the bit your after
00007840R4 SCREW 0.47 GBP 0.56 GBP 0.56 GBP
there is a part No. change along the line and i think this is the newer No. if not here is the other one
00006925J0 SCREW RLX 0.46 GBP 0.55 GBP 0.55 GBP
Re: Wanted Bumper Screws
Give Malcom Lockwood a ring. Or try Citroen customer services, they will do a dealer stock search off the part numbers.
Mike E (uk)
I have a few of the screws,they are torx on the later cars.
But you probably don't want them because they are not new.
I prefer new mike if i can get them yes but used ones wood be fine.
