TD clutch cable
TD clutch cable
Post by Mothman »
Hi, anyone got a TD clutch cable in reasonable nick? Need one asap.
Thanks
themildbunch
Post by themildbunch »
Sorry, don't have a spare but if you find one can you share your experience of changing it - not a nice job I think...
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Oilyspanner
Post by Oilyspanner »
If its the one with a weight on the end and a black plastic bit where it fits into the gearbox end I have a good one.
Post by Mothman »
Not sure if its the one bud, ile check with citronut.
I gather its a bastard to fit but much easier if the engine is out which it is.
Oilyspanner
Fitting should be a breeze with an empty engine bay :) are you doing the octopus while the bay is empty, and the rubber pipe that goes onto the back of the water pump?
pm me an email address and I will send a picture of the cable, I am certain it is TZD
Stewart
themildbunch wrote:Sorry, don't have a spare but if you find one can you share your experience of changing it - not a nice job I think...
two minutes if you have the engine and box remove :shock: :lol: :wink:
Oilyspanner/Stewart
pm sent
sorted thanks to GSF
thanks for the picy Stewart
although even with the engine and box out the tinny nylon ring that lock's the nylon feral into the pedel box bracket is a challenge :roll: :wink:
