I've booked the car in to my garage for them to take a look on Friday, but a quick hunt under the bonnet seems to have revealed the issue - part of the pushrod assembly (forgive my technical inaccuracies here!) seems to be half way to snapping hence the need to push the clutch further and further down.
Can anyone take a guess on whether this my be the sole cause of the issue or whether pressure from another fault is causing it to snap? Also - does anyone have one of these? I'm going to see if my garage can do a temporary weld/fix to keep me going and avoid total clutch failure!
Any pointers gratefully received....
