I had a friend ( mot tester ) look over my BX ( 3 months to go ) before its test and he commented on the rear suspension boots torn.
I used the angle iron method to straighten the small bars , thank you , and now I need two boots please.
Anybody know of a possible source for these .
I already have the securing pin replaced so it wouldn't be a long job to change.
Rear rubber boots
Discoil
Rear rubber boots
Land Rover Discovery TD5
Will the Xantia boot fit?
Have you tried your dealer? I bought one fairly recently and didn't have problems. I'd do it sooner than later, as I didn't spot a pinhole in mine until rust took a hold on the piston surface, meaning there was quite a bit of LHM passing the seals. I suppose a torn boot is less likely to hold much water, but even so...
- BXpat
Discoil
Discoil
I'm going to ring the dealer on Tuesday with the part nos supplied by toddao , many thanks.mat_fenwick wrote:Have you tried your dealer? I bought one fairly recently and didn't have problems. I'd do it sooner than later, as I didn't spot a pinhole in mine until rust took a hold on the piston surface, meaning there was quite a bit of LHM passing the seals. I suppose a torn boot is less likely to hold much water, but even so...
I've also found tel nos of 2 local BX garages within 20 miles of me.
Discoil
Update : :
Local dealer ( Huddersfield ) Not shown
Nearest Bx repairer. ( in Holmbridge ) supplied all part nos and home tel no. Not returned my call in 48 hrs .
Contacted Malcolm Lockwood in Bradford.
In stock of boots and clips and he posted them and the posty has already delivered them.
Fine day now required
