Hacking the Bosch injector pump governor
rmattila
Post by rmattila »
Has anyone any experience on modifying the characteristics of the XUD by changing the governor spring? I'm thinking of changing the spring to a weaker one in order to prevent rpm drop when loading the stationary engine - aiming at a constant velocity around 2000 rpm.
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
sdelasal
Post by sdelasal »
I wonder if you could use the cold start speed adjuster - When the wax-stat is cold, the lever gets pulled toward the back of the pump - adjust that to give you 2000RPM. When you want normal idle you simply push the lever to the front of the pump .... simple & might work!
electrokid
Post by electrokid »
I'd be inclined to put a servo control on the throttle cable.
2002 C5 HDi SX estate
rmattila
Post by rmattila »
Changing the two-phase spring package to a normal regular spring used in variable-speed control versions of the pump should in my understanding do the trick, if only the spring constant is correct. Might take a couple of iterations to get it sorted out.
