Up on ramps, depressurise , jack up offending corner , axle stand in place and remove ramp , securing pin removed and fixing clip undone.
Did not remove anti -roll bar as it was extra work but needed to get wheel lower , so I put some blocks of wood between the wheel and arch..
On reassembling it took ages to get the securing pin in
And then a reversal of the ramp etc.
The worst part of the whole job was getting all the ' gear ' together outside and then putting it all away again.
