Does anybody have that diagram but for a carburettor-type 1.6 petrol? Or know where I can find one?
Thanks
Right, now need part 6 on that diagram in case anybody has one floating around? It's graduated and my clever solution of just putting on a boggo 13mm hose hasn't worked at it leaks slightly at the manifold end. Failing that I suppose eBay may have some...NeilGP wrote:Bulletin-34
The inside diameter on the big end is 13mm and the small about 6 - I used a 13mm hose - so I guess despite my furious tightening of the jubilee at the small end it hasn't quite got a tight enough fit. Reckon the scrapheap challenge/bodge solution will be besttoddao wrote:You say it leaks slightly? Hope I'm not stating the obvious but is there a jubilee clip on there or some sort of clip?
Maybe ebay will yield something but there's nothing wrong with using what's available for a 'good bodge' - I found a 'graduated hose' as you put it as part of a VW hose from the scrappy bin, once I'd cut it down it was a good fit for an obsolete hose on my BX
