1.9 Petrol Bottom Hose
- Tim Leech
- x 150
The gt's bottom hose is spilt at one end and is dripping water, anyone know if new ones are available please?
Thanks
Thanks
- themildbunch
Re: 1.9 Petrol Bottom Hose
Is it 95610899? This is the part no for the 1.9 carb according to service.citroen..
Seems to be a Gates version here:
http://www.teilehaber.de/gates-kuehlers ... 63997.html
Hoses are getting a common issue and will get rarer - maybe we should make a list of the most common ones to go or be needed and check availability? A group buy on remade silicone ones could be a good way forward for the unobtanium ones...
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
- Mike E (uk)
I think I may have one here. can you post dimensions and Ill check it is the right thing.
IIRC, it came off a GTI, so may well be the same part.
Mike
Mike
- Tim Leech
- x 150
Thanks mike, im aiming to buy a new one if possible.
if its gone right against the pipe clamp at the engine end ( usual place as it gets doused in oil ) before the oil continues down to the lower engine mount ,
then you can usually cut it back and re/fit once,
- Tim Leech
- x 150
citronut wrote:if its gone right against the pipe clamp at the engine end ( usual place as it gets doused in oil ) before the oil continues down to the lower engine mount ,
Thanks Malcolm, will buy a new one if I can.
- Tim Leech
- x 150
No luck from my local factors or GSF, Citroen think they can get me one, its £40 but the original lasted 27 years.....
IF it is O/E part # 95610899 (and as per your Gates cat. link also states its also O/E part #95610898) therefore the actual hose should be identical/compatible !themildbunch wrote:Is it 95610899? This is the part no for the 1.9 carb according to service.Citroën..
There available from 'AEP DIRECT' which are more than likely to be O/E and much cheaper too (£24.14 delivered to you door ) !Roverman wrote:No luck from my local factors or GSF, Citroën think they can get me one, its £40 but the original lasted 27 years.....
Is, this the correct one ?AEP Direct wrote:CITROEN BX 1.6 & 1.9 PETROL (XU5M) - BOTTOM RADIATOR HOSE
*RADIATOR TO WATER HOUSING*
UP TO 07/1986
(RH543)
95610898
(NOTE: FOR RIGHT HAND DRIVE CARS ONLY!)
- Mike E (uk)
Whats wrong with a second hand one?
You can check if they are good by inspection, and a new old stock will probably be as old as the second hand one.
