I'm having a Peugeot 1.9 TD go into my BX17TZD and need a camshaft with a pulley to drive the HP pump. Apparently the ideal one would be from a N/A non turbo BX19 for better torque, but one from a BX 17TZD, would probably do.
I'd use the one I have, but would like to keep the head intact if possible, as it cost me £200 a couple of years back.
I could let you have the Peugeot 61K one in P/ex!
Wanted - Camshaft from N/A non turbo BX19
1992 BX 17TZD 130k
1987 BX 16TRS SORN
1987 BX 16TRS SORN
Re: Wanted - Camshaft from N/A non turbo BX19
I have one available, PM sent !
I had an engineering place drill and tap the standard non BX cam, then had a bx pulley bored out a little, no keyway, just bolted it up tight and plugged the oil return hole (M10 from memory)
