Wanted - Washer bar
Wanted - Washer bar
Hello
Mine is currently made up of a long length of some bright blue heatshrink.
Not very good. For some reason, try as I might, can't find some suitable black
tubing.
Has anyone got a proper set up, or a lead for where I might get some suitable tubing?
tubing.
Martin
Re: Wanted - Washer bar
try mig welder wire feed liner,
That's a good idea!
Something such as: http://www.ebay.co.uk/itm/SIP-Mini-Mig- ... _676wt_955?
Looks pretty thin, but might work.
Martin
Malcom Lockwood had two for sale at Wetherby. Not sure if anyone bought them. IIRC they are still available from main dealers. Got mine from AEP direct.
i think its very similar to the BX washer tube, it is quite think walled,Wooscary wrote:That's a good idea!
- Tim Leech
- x 150
I bought a new one at the northern rally to fit to the DTR, your welcome to the old one if its serviceable
Tim, that's very kind. If it'll do the job, name your price! Always a fan of reuse if possible. Cheers.
Martin
- Tim Leech
- x 150
Send me your address mate, if it works you owe me a cuppa!
Brilliant, cheers Tim, if you're sure. The kettle is always on in Manchester!
Martin
Tim, arrived today, perfect!
Many thanks again.
Many thanks again.
Martin
I know this case is closed now but I remember that ole David Rutherfold used to remove the spray bar from some Peugeot model (405?) to fit on his BXs as it was a more solid rubber thing. Anyone confirm this or actually done it?
I've heard that too, but then 405s seem nearly as rare as BXs round here so not sure on wide spread availability?
Martin
- Tim Leech
- x 150
Wooscary wrote:Tim, arrived today, perfect!
Many thanks again.
No worries mr, That took a while!
