Mk2 hatch nsr 1/4 panel
- Tim Leech
- x 150
I should have known, the one i bought on ebay for my mk1 and was told its the right part isnt!!
Its a genuine Citroen part and brand new.
Cost me £75 but will take £50
Re: Mk2 hatch nsr 1/4 panel
is there a difference between MK1 and 2 rear quarter Tim
- Tim Leech
- x 150
Yes sadly, theres alot more flared on a mk2 and have a hole and recess on the arch for the stone protection moulding. I considered cutting it up to use as a repair panel as but the profiles wrong.
This one below doesn't appear to have those features /\ :-Roverman wrote:Yes sadly, theres alot more flared on a mk2 and have a hole and recess on the arch for the stone protection moulding. I considered cutting it up to use as a repair panel as but the profiles wrong.
BX saloon LH rear wing £40
Also looks to have an O/E part no. stuck to it !
Check with David the part number as it does not appear to have the 'hole and recess on the arch for the stone protection moulding' features like the one which you spotted on E-Bay (albeit being the O/S) as in THIS thread for additional info
It does look like its for a MK1 , exactly what your looking for (David's PARTS FOR-SALE thread) !
Best of luck
- docchevron
/\ definitly a Mk1 wing that one
i'd say probably for a Valver as the lower half flairs out below the trim Chanel,
- Tim Leech
- x 150
Excellent thanks, Ive tried getting hold of david but no success!
what is the part No. om this wing i cant quite read it,RxBX wrote:This one below doesn't appear to have those features /\ :-Roverman wrote:Yes sadly, theres alot more flared on a mk2 and have a hole and recess on the arch for the stone protection moulding. I considered cutting it up to use as a repair panel as but the profiles wrong.
Best of luck
Part number on that panel is, 95 559 434
Brian.
Brian.
2003 Saab 9-3.
- Tim Leech
- x 150
Thanks brian, the one on mine is 95612062. Hope i hear from David.
- docchevron
fixable to be fair, if you cant get another, but the one in that picture above is without any doubt at all a Mk1 wing.
- Tim Leech
- x 150
Good stuff, its mendable but my bodyshop are more fitters than repairers.....
- docchevron
yeah, you'd want a good fabricator to get it looking right really.. a new panel is always easiest, when you can get them anyhow..
- Tim Leech
- x 150
The Mk1 panel that David had has been sold im told to someone else. Im hoping they may have bought it thinking its a Mk 2 and a swopsie can be done.
