I can cover postage and whatever the bolt is worth to anyone
Wanted: Starter motor bolt
Matt H
As I recently discovered a bolt missing from the starter motor, I was wondering if anyone had a spare one lying around?
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
Re: Wanted: Starter motor bolt
what length? there are two lengths, and you don't want to stick the long one in the short hole, so to speak!
PS they are a standard size bolt, if you look on the Citroen Parts list it tells you size, length, thread depth etc
Matt H
It's the bottom one if that's any use... The other two I took out were the same length.
