Rear light for estate?
Ant
Post by Ant »
Hi,
I've just registered on the site at Remy (very helpful at Medway Citroen) suggestion. I've been blessed with a TZD estate bought three years ago (96k miles) which has barely put a tyre wrong 40k later.
Then last night, during the 20 minutes while I was chatting in a mate's house at the top of the hill, a cotswold stone wall apparently crept up the hill, subdued the car by bashing the rear offside/drivers light pod and then dragged the whole car down to the bottom. I was fortunate to return to the scene and flee before the wall had its wicked way any further.
I don't know if I have the guts to continue to drive past miles of cotswold walls who must be just licking their lips when they see the state of the car. Does anyone have urgent access to a spare lens/assembly before they finally close in?
Ant
Re: Rear light for estate?
hi Ant and welcome
i dont have a spare light lens but how fast was the wall traveling,
Ant
Post by Ant »
Thanks for the welcome!
The wall was so sneaky I didn't even see it move.
Believe it or not the only damage is to the indicator part of the lens and module and the plastic tab holding the bumper trin strip. The hand brake tried its best but just wasn't pumped enough and the bumper just popped out of its fixing.
The problem is that a flashing white light will attract a flashing blue light!
Ant
as a temporary fix you can buy tinted coloured lamp repair tape from the likes of Halfrauds,
also i would suggest with the car on level ground, engine running, hand brake off, press hard on the brake pedal 3 or 4 times, but dont stamp on the pedal just press very hard,
this will adjust the hand brake mechanism in the front calipers, as long as the levers on the calipers are going fully off with the hand brake released,
thought you would like this ](*,) ](*,) :roll: :shock: :lol: :wink:
Post by RxBX »
Hi Ant and welcome !
CGATCX25GTITURBO wrote:I pm'd, my brother has a pair on an Estate sat in his garden a bit cheaper :)
The above quote from THIS thread, was the offer taken up ?
If not, maybe worth pursuing :wink:
Ant
Post by Ant »
Thanks Malcolm -good advice but the wall isn't moving!
Any lead from anyone on who might have a spare one in the shed who imay not be currently online would be a great help and relief!
Ant
RxBX many thanks - I,ve just emailed him
CGATCX25GTITURBO
Post by CGATCX25GTITURBO »
Ant wrote:Thanks Malcolm -good advice but the wall isn't moving!
Ant
Hi, thanks for putting the link in and I've replied to the PM
Neil
missing my 1992 BX19TGD
1987 BX19 GTI 8)
19TD temp 2 Xantia estate :)
600 Bandit 97 :)
ZX12R 00 :evil:
another good reason to always leave the car in gear when parked!
docchevron wrote:another good reason to always leave the car in gear when parked!
or just make sure you calipers have adjusted up properly every opportunity you can,
like on a garage forecourt before/after putting fuel in,
these adjusters very seldom work in normal use as they are supposed to,
so if they havent adjusted them self's it wont make any difference how far or hard you pull the lever up in the car (feet on dash comes to mind :twisted: :shock: :wink: )
they realy do need help in adjusting as above on a regular bases
electrokid
Post by electrokid »
Or short term get an amber indicator bulb - available everywhere.
2002 C5 HDi SX estate
Ant
Post by Ant »
Hi,
good tip about an amber bulb - I had heard a rather odd sounding concern that some amber bulb base terminals might not line up in a standard fashion. Assuming I find one which definately lines up I'll keep it as an onboard spare because it looks like when the estate's rear bumper is compressed at the corners it wil probably bulge upwards with predictable results to the light assemblies specailly the indicator section!
Ant
no good Brian
as the Amber bulbs have off set locating prongs, not directly opposite each other,
My Mk2 estate has a tape-repair to the indicator on one side. I've no idea how long it's been like that but that's how it was when I bought it in 2009!
citronut wrote:the Amber bulbs have off set locating prongs, not directly opposite each other
You can buy them with offset or straight pins if required.
Indeed you can. My 2CV has 'straight' pins for its amber bulbs as I've fitted clear lenses. Slightly harder to track down but they are out there.
