seat belt anchorages
Phil Brook
Anybody know where I can obtain new anchorages for the front seat belts. The current ones sometimes won't let go requiring undignified exits!
Philbrook
Brian
Re: seat belt anchorages
Hi Phil,
I am not sure if they are available new, but try this first:
Next time you are in the garage inflating / checking your tyres pressures, giive the seat belt sockets a generous blast of compresed air
Then apply a short squirt of WD** or similar, and see if that does the trick...Works for me...
Visa 17D 1986 192K Sorn
BX 17TZD 1992 192K
306 XRDT 1996 175K
BX 17TZD 1992 192K
306 XRDT 1996 175K
I'm sure there's plenty of people here with spares, although there are 2 different types on Mk2 cars..
do not use that orible W stuff as it does NOT do what is says on the can, i belive it is deliberately designed to cause you to use more on most applications it states on the can,Brian wrote:Hi Phil,
the usual is spray it on your ignition HT leads to help start the car, trouble is it attracts dirt and dust which in turn soaks up moisture, so causing what you were using it for in the first place,
if you have to use a shaky can use the 3in1 one,
