Hi,
I need a rear suspension cylinder for a hatchback BX please. Can anyone help? Thanks.
Regards Graham
Rear suspension cylinder wanted
pwykes
Re: Rear suspension cylinder wanted
Hi.
Just converted my bx 1.9 rd estate using xantia cylinders.The ones i have taken off had an internal bore of 37 mm.The ones fitted had an internal bore of 35 mm, but it works ok.I believe 35mm is the correct size for the hatchback.info can be found on website.There are two NON hydtractive cylinders left on Ebay priced £82 + £6 delivery.
Cheers Phil.
Cheers Phil.
Hi Graham, I thought you'd got fixed up ?ghaddon1701 wrote:Hi,
Regards Graham
The above quote from THIS thread (for ref.) !ghaddon1701 wrote:I have managed to locate a second hand cylinder from a Citroën breakers in Billericay. Very helpful people. The phone number is: 01277 651 486 if anbody needs any second hand bits. Thanks.
Regards Graham
Phil, as can be seen from the thread in the link above to Graham other posting all the info is there including 'rmatilla' comprehensive MACHINING method !
So if Graham's got let down (Indeed if its for the same BX as he may have more than one) and as his is also an Estate and you stated "The ones I have taken off" which I read as you changed both ?
The E-Bay XANTIA ones
