Hi
I hope I won't upset anyone if my first post is in here. I'm a member on the French car forum, but I didn't get interest there and this seems to be a better place for this
I have a pair of left hand drive headlamps which fit the later shape BX front.
They were used on my 1989 turbo diesel BX, supplied secondhand by a German dealer during a temporary accident repair, and then replaced with UK ones when I got home
Then I swapped them in for occasional trips abroad, and although the car is now long gone I still have them here in boxes.
If anyone would like these for the same reason I don't expect to get actual money for them, just the cost of a courier to ship them.
LHD headlamps
Re: LHD headlamps
Thats very generous of you, I would have snapped your hand off last month but no use to me now.
- x 116
Re: LHD headlamps
I would find these useful so ---PM sent.
Re: LHD headlamps
as far as im aware all BX headlamps are the same shape/fitment all rthe way through,
Re: LHD headlamps
i didnt mean the difference between the beam pattern/kick up Tim,
i ment the physical shape and mounting,
Re: LHD headlamps
Ahh yes, in that way the fittings are the same....
KevR
Re: LHD headlamps
Following on from this, I'm pretty sure I've got some RHD headlamps which are no use to me! If anyone wants them they can be available for pickup from Loughborough area or posted at cost within UK early July.
andy5
Re: LHD headlamps
Yes, they just clip on to those sort of ball ended studs, change over in a few minutes, no adjustment neededcitronut wrote:i didnt mean the difference between the beam pattern/kick up Tim,
Mind you, I didn't actually swap them at Dover, just taped over the sloping part of the dip on the LHD ones for the UK part of the trip
