Still after a few bits!
Fitted the leather seats to the trs a few weeks back to enable the tweed to go in the DTR, went to drive the trs today round the yard and the seat belt clip wont fit in the buckle..... Its a 89 mk2, the original buckles are just plain with no "press" on them.
Also i need a later type side light bulb holder and a nsr bulb holder off an early car.....
Not asking much am i!
Re: Seat belt buckles and bits
I think there are two types of belt/buckle combo and being typical Citroen, I suspect they were in use consecutively. When I put a valver interior in the Green Tiger, I had to change over the buckles as well as the seats.
Ahh ok, the seats from the TRS fitted the DTR no problemo, do you still have the seats you took out of the Mk1? if the belts fitted the seats I gave you then they are the type I'm after....
Hmmm. I had to swap the buckles. Wonder what I did with the old ones...
If you can find them i would be very grateful....
Still needed please!!
Everything located now thanks chaps!
Re: Seat belt buckles and bits (now sorted thanks)
Spoke to soon! The one i bought was wrong.....typical!
Chaps i need a sidelamp bulb holder still, the sort for the later capless push in bulb.
Also the horn on the DTR died!
Thanks
Re: Still after a few bits!
Tim, have you got any NOS headlamps lying around? Reason I ask is when I put the new lamps on the valver last year the side lamp bulb holders were already in the lamps. Failing that Citroen main dealer perhaps.
Checked my stock, none present.
NT Shaws?
Someone must have one!!
Post by RxBX »
Tim Leech wrote:Spoke to soon! The one i bought was wrong.....typical!
Thanks
a) Was the side-lamp holder that I offered you on your last visit, the correct one by any chance ?
b) The horn, is that a pair or a single one ? (I should have plenty in stock) !
Call or PM me !
Thanks Richard, yes the one you showed me was the correct sort.
Post by RxBX »
Tim Leech wrote:Thanks Richard, yes the one you showed me was the correct sort.
Would you like the bulb holder posting or are you wanting the horns too (No pun intended) ?
If so, I'll check out my stock and test them first so you can do a pick up for all the bits if preferred ?
