Hi everybody,
I don't suppose anybody knows where I can get the item number 6 in the picture. Citroen part number 95559360 or 372614. It is no longer available from Citroen. or could anybody tell me of a substitute. The ones on both sides of my car have nearly rotted away. It is supposed to protect the seal on the back of the rear hub bearing, it actually touches the seal when there and help to keep water moisture out. We would try to make one but it is quite a complicated shape. Any ideas will be much appreciated. Thanks.
Regards Graham
Also the link for the picture http://www.numcat.ru/citroen/6/1CVD/025203434430/" onclick="window.open(this.href);return false;
Rear hub bearing cup
ghaddon1701
Gibbo2286
Re: Rear hub bearing cup
I've got three of those new in the Citroen bag. Two for a fiver including the postage ok? Provided you're no the other side of the world.
ghaddon1701
Hi,
Thank you for reply to my post. I will let you know a bit later on tonight. I may have have found a substitute. I am in fairly desperate need for my car back as I use it for work everyday. But if the substitute does not work I will definately take you up on your offer. I am in Halesowen near Birmingham. Thanks.
Regards Graham
Regards Graham
that second No. also fits C15's and XANT's
here is price and part No.
0000372614 BEARING CUP 0.74 GBP 0.89 GBP 0.89 GBP
Gibbo2286
I had to have a guess at the price Citro, the ones I have are the part number3726.14 and came as part of a job lot I bought from a closed down dealers, very few items left in that job lot but I keep finding the odd bit.
ghaddon1701
Thanks everybody. Citroen are aware the part existed as they usually are but also as usual it is followed "by sorry it is no longer available". I thought it might be seeing as it also fitted the C15 which they only stopped making a few years ago. We have managed to fabricate something out of something else that does a similar job on something else, if that makes sense. Thank you all.
Regards Graham
Regards Graham
it also fits the XANT
Gibbo2286
Well if anyone else has the same problem the three new ones I have will be here on my shed shelf waiting for a buyer.
rmattila
I took measures of a new one and turned a pair of moulds in order to press new ones once I've emptied my stock:
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
