just a quick hello as I've recently acquired my first Citroen, a BX 19RD estate (formerly of RobT) I swapped it for my R25.
First impressions are I don't hate it, theres a couple of things I need sorted asap though.
The drivers seat feels like it has a metal bar near the top that presses in to my back. Is there something I can do about this or does it need a replacement seat? If so are there any other seats that will fit a bx?
The drivers window doesn't close properly without assistance, it's like it comes slightly off a runner or something near the top. Is this common? easy fix?
Anyway, the drive home from Cambridge (where we met for the swap) was fine, the engine doesn't feel as gutless as I was expecting. The clutch is stiff and juddery and the brakes, while good, have an odd feel to them, but I can live with these. I am slightly concerned about the amount of diesel I appear to have used, 1/4 of a tank for 80 miles, I'm hoping the gauge is being a bit French.
ps. I use several car forums so if you've seen the username elsewhere its probably me
