cooling system
halima99
cooling system
Post by halima99 »
Hi guys, my radiator seems to be building a lot of pressure, I have taken the radiator out and flushed it, but it still seems to build a lot of pressure, the top hose is warm, but rad is cold, however when I release the rad cap it holds a lot of pressure, could anyone give me some advice on this cheers.
Re: cooling system
Sounds like a airlock!, get the heater on full and with the engine running and radiator cap off undo the bleed screw at the opposite end of the radiator to the filler cap.You should here the air come out followed by a flow of water, top up the coolant as you bleed to force the air out.
halima99
Re: cooling system
Post by halima99 »
tried doing that but still seems to be building pressure.
Re: cooling system
Have you checked your thermostat is opening?, try taking it out temporarily just to eliminate it.
halima99
Re: cooling system
Post by halima99 »
will giv that a try, thanks
Re: cooling system
Post by Mothman »
Head gasket?
Re: cooling system
Mothman wrote:Head gasket?
We are hoping to avoid that one :wink:
Re: cooling system
Post by kiwi »
You will do well in New Zealand as a mechanic! First thing that gets blamed and then fixed is the Headgasket here! You only have to look on the local online car sales to see the most common thing mentioned is Head Gasket.
I doubt HG until every other solution has been looked at including blocked Radiator.
btw, should this not be in technical? Just being picky
1990 BX19 TZS Auto 06/11/1989
Re: cooling system
If the radiators cold then it still sounds like a blockage, is the heater getting warm?
Re: cooling system
Roverman wrote:If the radiators cold then it still sounds like a blockage, is the heater getting warm?
Thermostat not opening is a blockage..... :roll: :? :wink:
halima99
Re: cooling system
Post by halima99 »
yep, heaters getting warm.
